Media The MUD 100 series Photos thread (43 Viewers)
Photo/Video/Audio threads
You captured my future goal! Back in July…
My buddy and I removed the worn out suspension setup I've been running for almost 8 years now, which consisted of Ironman FCP shocks, the old version poly Nitrogear UCAs, OME tbars and Slee heavies with a 1" puck and gave the old girl a bit of an upgrade!
New setup: Nitrogear UCAs, stage 2 Icon shocks, new OME tbars and OME 864s. It rides incredibly well!
I have been running the same shocks and UCAs for a while now, and I have liked them so far. Pretty floaty over all but the worst washboards, and even then a little more speed often smooths it out.
It might be the 265 tires that make it look taller than usual.
I’m running an old man emu setup and 285s. But for reference, my center hub to fender measurements are 21.5 inches front and 23 inches rear.
Your front end measurement of 21 7/8” is just a bit higher than the recommended maximum of 550mm or 21.65”.
Yea might be the 265's I actually just walked out and measured and my lift is identical to yours at 21.5 front and 23 rear.
My droop is at 55-57mm l/r sides though.
Yeah, you're probably fine. I just mentioned the max number of 550mm because I remember reading up on it here a while back. I couldn't find the post but Christo Slee said something along the lines of keeping the front end between 500-550mm static height. It also could have been on Slee's website. You're not too far off.
My helper here. Planning to install this week. ASFIR was great to work with. Orderd 9/22 arrived 9/27 from ISRAEL. Pretty impressive, aluminum skids with shipping under $1,000.
