Builds The honey badger build (5 Viewers)
No reason other than i have them . The packaging is getting real tight. so i may Not end up using them .
I have to ask...why are you running bypass shocks on this rig?
Blasted and PC my aprons
Ok I had to give up on the bypass shocks for now. Just not enough room to fit all my steering stuff . And actually be able to work on it if I ever have to . I added on 2 inches to the towers and She is back on her Feet 😳.
I also received the correct pulley today I got that installed and back on
That is at 4.5 of up. I was aiming for 4. Wheels lock to lock I have about 2 inches till it rubs the fender 👍. I know when it articulates it will be close
With out the extra shock I can fit bump stops 👍
I love the older emblems, what's your clearance turning left on that fender? And I can go back thru the thread but did you move the fender edge forward at all?
Fenders are Tube Fenders i made. At full Lock. i have about a inch at the front. My guess is it will rub . But i can set the bumps . Once i get it out i can really see what it does in real life .
Full bump. Center - Lf -Rt In fact I don’t even have my steering stops set so it will be a little less.
Drop looks good
Burned in the coil mounts And she is standing on her own feet again .
My links are done 🤩. My new link mounts are due to arrive tomorrow also so I can get this thing DONE !
I changed out the link mounts tonite. So they match what I have in the rear. I just did not like the look of the others .
Are plasma table cutting your own link mounts or using one company's over a other. I ask because I have a few different companies here to test fit and was wondering which you prefer. I like the keyed plates
The ones i am using are from TMR. The others were from Balistic
Send it Sunday. Melted some butter in. And my finger just so I can feel alive 🙄.
Ok we are close. I just need to make the track bar . Waiting on the bungs . I will throw a diff in the front to get the measurements for a driveline to get that going . I go to Moab next week so not much will get done this week as I need to get ready for that. I also moved the axle back a inch to give more clearance. At this point I am just going to get it together so I can use in in June.
