Builds The honey badger build (2 Viewers)
So I am not Running a 40 inch spare. Would look stupid and take up the entire rear end. So. Quick call to my design team and going with something like this . I will use one of my Roam boxes And then run 2 fuel cans . Maybe stick my high lift back there somehow .
My goal was to cycle the suspension this weekend and well it works 😃. Nothing binds. Really happy. I have it set to have 4 inches of up travel and the rest droop. I may raise it another inch. D
So here are some critical milestones .
Feb. Install Orion t case. @Valley Hybrids
Get new driveline @ South Bay driveline
Get exhaust installed
Install the Sniper efi
March
Install seats
Get front end done
April
Wrap up loose ends like brakes and mount winch arb comp ect
May Test test test
June it’s go time. Big trips planned for the rest of the summer
So I seen where someone else used this same rear set up only difference is he used the link calculator 😃. I had everything the same except my axle mounts. I had them
At 12 inches of separation. By the calculator and with 40 inch tires I should be at 10 inches. . I had some different mounts I liked better anyways. So I ran home today and cooked some up. Moved the mount to 10 inches and Boom we are at 103 Anti squat 🤩. Going with it
Very nice
So when I would cycle the rear it would not drop as far as I hoped for. Then I noticed the opposite side was hitting on the leaf spring mount 😞🤔. So I got a new toy 😃. She drops to the floor now. Nothing touches.
Nice choice. I’ve eyeing them. Just need to select one that work with the CNC table I’m interested in.
So I can fit the coilover like this 🤔. Without cutting the tub . I am not opposed to cutting but would prefer not to if I don’t have to. It’s kinda a one shot deal doing that . Thoughts🤷‍♂️
Another option :hmm: would be to not use the coil mount. But to put a plate that ties into the cage and then make a sort of hoop that ties back into the frame
Thinking this will look cleaner
Can we see where and how you are mounting the upper mount of the shock. Under the tub?
yes i will install them this weekend
