List of Threads / Tips / Tools / Links for anyone preparing to do a lift on their 60 / 62.
Don't let this post overwhelm you, you can definitely do this. I am a pansy-ass office-ridden engineer, and did this by myself with the right tools in two leisurely days.
Prep
Which Tools to use:
https://forum.ih8mud.com/60-series-wagons/280692-fj-60-old-man-emu-install-my-tips.html
Install
General Install:
https://forum.ih8mud.com/60-series-wagons/245330-fj62-ome-lift-installed.html
Lift one Man job:
https://forum.ih8mud.com/60-series-wagons/595113-my-ome-install-one-man-job-my-tips.html
Suspension Install Sequence:
https://forum.ih8mud.com/60-series-wagons/573951-suspension-install-sequence.html
Man-A-Fre Leafspring Installation Instructions:
http://www.man-a-fre.com/technical_info/60seriesleafspringsuspension.htm
Details
Cruiser Outfitters OME Tech Page:
http://cruiseroutfitters.com/tech_OME_leaf_tech.html
Caster Shims:
https://forum.ih8mud.com/60-series-wagons/159526-caster-shims-ome-front-springs.html
Post #25
Jack stand Placement:
https://forum.ih8mud.com/60-series-wagons/519504-dumb-question-about-doing-lift.html
Rubber rear pad:
https://forum.ih8mud.com/60-series-wagons/513251-need-quick-ome-lift-install-question.html
Torque Values
All values are listed in FT-LB
Additional Parts suggested
Shooting Trouble
Do your own alignment:
https://forum.ih8mud.com/60-series-wagons/76961-do-your-own-alignment.html
Steering wheel not straight: (start with post #5)
https://forum.ih8mud.com/60-series-wagons/647032-fj60-steering-wheel-misalignment.html
Cruiser Lean:
Looking for a good thread
Stinkbug:
Driveline vibrations:
Other issues?
While You're Down There
Body lift / puck replacement:
https://forum.ih8mud.com/60-series-wagons/383596-body-lift-pics-parts.html
Axle Paint Inspiration:
https://forum.ih8mud.com/60-series-wagons/141404-out-hibernation-2.html
Axle Paint Discussion:
https://forum.ih8mud.com/60-series-wagons/271441-axle-housing-clean-up.html
Assembly tips:
Recommended Tools:
(wngrog, aktaku, Zhenya)
Mandatory:
Optional (good for rougher rigs)
Tire/wheel combo that fit
Tire/wheel combo that rub
Other Threads:
https://forum.ih8mud.com/60-series-wagons/506131-ome-lift-install-question.html
https://forum.ih8mud.com/60-series-wagons/602434-tools-needed-my-lift-kit-install.html
https://forum.ih8mud.com/60-series-wagons/579358-what-else-do-while-putting-lift.html
Prep
Which Tools to use:
Install
General Install:
Lift one Man job:
Details
Caster Shims:
Post #25
Rubber rear pad:
Torque Values
- U-bolts - 90 (fsm calls for 105)
- Shackle 22 mm full nut - 60
- Shackle 22 mm half nut(zerk side) - 30
- Fixed Pin 22mm - 60
- Fixed pin Retaining Bolt - 17
- Front Shocks: Top stud mount @ Frame - 19
- Front Shocks: Bottom Mount @ Axle - 47
- Rear Shocks: Top Mount @ Frame - 47
- Rear Shocks: Bottom Mount @ Axle - 27
- 90 degree Grease fitting - (general replacement size 1/4" 28 )
McMaster-Carr: http://www.mcmaster.com/#1/4"-28-grease-nipples/=kyb7z1
Lowe's: Part # Item #: 218980
A 90 degree fitting is recommended for the exhaust side upper shackle grease fitting. If use the one provided you will have to loosen your exhaust to access to the fitting - Napa extended brake lines 22 1/2": Napa UP 38009 (Kurtis)
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=UBK38009_0331671144
Attributes:
Hose End Type 1 : M10 x 1.0 Male
Hose End Type 2 : M10 x 1.0 Female
Overall Length : 22" - Extended breather hose:
- Replacement small bolt that holds the fixed end pin in place
M8x20 - metric 8mm
Shooting Trouble
Cruiser Lean:
Stinkbug:
Other issues?
Assembly tips:
- firmly block the other tires. When doing the front axle, set the e-brake. When doing the rear axle, lock the front hubs and put the truck in 4WD. (KLF)
- yea get a couple good jack stands to put under the frame in front of the spring hangers, then 2 more to go under the axle, pull both tires. best to just do one corner at a time. the other side kinds holds things in place. (slacker24-7)
- I always jack the truck up using my floor jack under the spring perches on the axle, and then place jack stands under the frame right behind the bumper. When working on the front end, I also place jackstands under the frame behind the leading edge of the front doors. Belts and suspenders. Then I let the floor jack down so the vehicle settles onto the jack stands. Before I get under it, I shake it really hard to make sure it is going to stay put. I have 8 jack stands--four 6 ton, two 12 ton that reach way up, and two 2 ton that I use for axles.(slcfj62)
- Cheap Extended Brake lines:SS lines are a waste of $ IMO. just go to napa and order two stock lines for each side and screw them together for your extended brake lines....Only $6 for extended lines! (alaska60)
- The military wrap should be on the non shackled mount.(rcj1)
- The plus sign (symbol) or minus sign (symbol) does not indicate the orientation of the leaf spring.(rcj1)
- Mount the leaf spring with the wrapped end in the middle of the vehicle and the non-wrapped end on the outside (closest to front/rear bumper).(rcj1)
- Don't be afraid to ask questions (rcj1)
- You should also not tighten everything completely until the weight of the truck is on the new suspension.(RMP&O)
- Remember to remove the grease zerk from the slip joint of the drive shaft. (Rigger)
- If fitting the rear spacer the spring pin, fit it to the spring before attaching the spring(Zhenya)
- When removing the shackle pin, spin the nut off till the edge of the pin, do not take it all the way off. Now you have a bigger surface area to hammer on, and you won't mushroom the pin.(Zhenya)
- Keep the u-bolts loose until both sides of the axles have the spring pins in the right place (Zhenya)
- The Zerks and half-nuts go on the OUTSIDE of the chassis (Zhenya)
Recommended Tools:
Mandatory:
- 4 quality jackstands
- Floor Jack
- 10, 12, 14, 15, 17, 19, 21mm , 22mm sockets (deep)
- A nice punch set - Push the pins through the hangers
- rubber mallet
- 3' breaker bar
- Pickle fork or gear puller for steering stabilizer removal (Elbert and BG_TX)
- Napa Auto part number for pickle fork BK 7769065
Tie Rod Removal tool on amazon (lovetoski) - Vice grip- to help work the hanger pin out
- Angle Grinder
- Heat source - cutting torch or propane torch
- 5# and 12# sledge hammers
- Air chisel (optional, but nice to have)
- Impact wrench
- Sawzall
- ratchet straps/come along
- Cutoff wheel to cut down the u-bolts (BG_TX)
- BFGoodrich - AT T/A KO 33x10.50xR15 / Stock Wheel
- 31x10.50xR15 / Stock Wheel
- 35 12.50x15" BFG AT's on 10" wide rims (Mace)
Other Threads:
