Any issues? I've religiously used 5W-30 M1.
could that be because it's cold in Chicago right now?
anyway, what did you tell them you wanted done?
Drain a quart or 2 and add some 40 or 50 weight and you'll have your viscosity back to a 30 weight. 20 will harm your bearings, etc.. at normal temps.
Do we think a 50 mile commute tomorrow would do anything negative? I'm an OCD engineer.
This isnt the first "designed for 5W-30" engine that Toyota now puts 0W-20 in...early V6 FJ's and 4R's and late model 200's.
You'll be fine but why drive 50 miles to drain 2 qts of oil?
Newer engines have the 5w20 designed into the tolerances
No Land Cruiser on that chart???
Turns out Toyota thinks it doesn't need oil.
