Finally go t the Tough Dog setup installed. I went with the adjustable 45mm setup with the 0-660# load rate TourFlex coils. After talking with the shop (SD Trux), I decided to go with SPC UCA's. I know a lot of people have installed this kit without them, but several people I talked to said that it was a no brainer to upgrade the UCA's at the same time.
So this setup ended up costing between the standard OME and BP-51. We will see how it shakes out over time. Had i known I was going to do the UCA's I might have made a different choice, but again, silly to think too much on it without putting some miles on it.
I will say, it seems to have lifted it more than expected. Surely that will settle after driving it and even more once the sliders, front bumper, rack etc are added.
Makes the 285/70/17 tires look small. SD Trux was worried that a bigger tire would rub the KDSS and even said to keep an eye on it when airing down. Will probably wear out these tires that came with the Rock Warriors before making a change regardless.
This weekend the ARB dual compressor gets installed as well as some progress on the rear drawers.
Making a custom set of drawers out of the pile of 80/20 i have left over from my campervan build. Should be able to get away with only purchasing the UHMW slides and birch for the top/drawers. Hence why some of the fastener choices may not be what you would pick when building from the ground up.
But the result will be strong and light.
The goal is to be able to take this in and out quickly. Drawers will be very easily removed and 4 U-bolts will hold it in place with the below brackets. Did not realize this is how the KISS drawers are held in place until I looked into how theirs was done. Happy to see I was on the right track.
For our sleeping quarters when the whole family comes along, we settled on the RX-5 OzTent. Hesitant about a ground tent, but more hesitant about climbing up a ladder with a small child and 90lb dog.
The most important part of it all is that we successfully got some permits to do the White Rim Trail late May as well as a night out at Point Sublime on the North Rim. Two destinations that have been on my list for a while and we needed a "purpose" for the build to help drive decisions.
I've been thinking about building some drawers for my 200 and possibly using 8020 got the frame so I was super excited to see this post.... And then super let down to see you bought the ARB's ... LMAO. I may still try to build a set but who knows. Great build.
