Builds The Boujee beater (1 Viewer)
Funny, the last 2UZ timing belt I did was in an in-insulated garage where we burned through 40# of propane to stay warm :). Not a bad job at all really.
I assume it is still cold there...sucks! We are entering the warmer wet weather and the pollening has started in GA.
Yeah it’s chilly here but not cold, yesterday was the warmest day we’re going to have for a while, 45 degrees.
Plus I have a small event the 17th at good evening ranch, so pushing a little to get it done now.
Ready to fire it up in the morning.
Yikes....wonder what is in mine!
How appropriate to this forum.
Not s’bad, there.
Did you install ACC’s Tie No Bo stronger tie rods? If so, any thoughts?
I have them on my truck and they work fine but you have to cut the tie rod boots just right to sit in the groove of them. I also had to tap the threads of the inners another 1/2" as they wouldn't screw in far enough to align. That was pretty easy but I needed an M15x1.5 die. So far so good
Other than just the thought that they are stronger, any perceptible difference?
Literally zero difference in handling or anything that I've noticed. They just strengthen the tie rods so you break your rack instead 🙃
What rake are you set at?
