We have 12k warn winches on our f550 fords that weigh 18k, we constantly snap 3/8 steel winch lines. But that's what the power company transportation department specs for the vehicle. I just stand at the end of the controller cord in the clear.
Another thing to think of when doing those 'which winch is good enough' - is looking at the rating by what wrap on the drum you're in.
Part of why I always do a simple compound pull is all I add is a pulley, but I get twice the rope off the drum.
Since winches are about getting going over 'how fast am I going', me cutting my linespeed in 1/2 is a thought I never bother with.
I suppose I'm using 1/2 the amps, but I'm on the amps for 2x longer - I'm not a battery guy but to me either what I'm doing is a wash, or slightly easier on my single battery/hand throttle setup. IDK, have zero facts to back that.
Frankly linespeed is a factor only if you're a Pro3/4 or KOH guy, and even then those guys you see leave 15-20' of line wrapped on the bumper to save time -- to me for our crowd linespeed is a non-factor.
Seems like an awkward winch to work on, I came up with this wood brace to it still while I work on it.
Does this make you horny baby?damn it all, here we go again with the winch debate. Can we all just get along and enjoy the winch porn?
Admittedly, I have dirty thoughts of finding a 8274 on the local CL and then figuring out ways to stuff it in the ARB.
JG2=
J is the the 10 letter in alphabet. SO MADE IN THE MONTH OF OCT.
G is the 2nd work day of the week. SO MADE ON A TUESDAY.
2 means it was made in a year ending in a 2. Or 1982, 92, 02, or 2012.
At least that's how I read the Warn 'code' I looked up.
You can email Warn and they'll give you the info. I found their customer service to be exceptional when I was doing my rebuild.Yeah, that's what I gathered too and am hoping that the s/n might produce a more accurate DOB. Not that it really matters, any of these babies are rebuildable.
Just give me some time and I will have it on the ARB. I have no other choice now. Not looking to do a hack job so it may be a few weeks. Pretty stoked about though!
Also the oil was low, probably because of the leaking seal.
It probably has leaked some of the lubricant, but be advised...the unit is designed to use only 6 fl. ozs. of oil anyway. I used twice that amount when I did mine, which just brought the level up to the drum seal in the lower case.
I want to put a drain and fill plug in but I am not sure were the best place would be to install a drain plug for access on a 4x4 labs bumper.
The lower case on the winch pretty much dictates where you can install a drain plug. You have a little leeway in the positioning but I'd recommend not getting too close to the radius of the lower case and stay next to a reinforcing rib if possible.
