tachometer wiring order?? (1 Viewer)
Ft Worth, TX
Anybody know, the order the wires are supposed to go in, on the back of an FJ60 tachometer??
Thanks,
Richard
There's a schematic in the back of the chassis manual -- don't know off hand.
Can download here
Index of /Cruiser and M416 Manuals
Q : They're just connectors. Are you trying to wire in an aftermarket ?
No, sir. I am attempting the same mod as tee bags building a factory tach, project. as i have read through the FSM, i get a little fuzzy... I know the WB and RG wires are for the light, WB is the light ground and RG connects to the tail light circuit. The BY wire goes to the negative side of the coil, I now have two remaining wires, B, black and R, red. I would assume, that would be a ground and an ignition wire, and I would furthermore assume the Red would be ignition, and Black ground. The FSM is pretty clear about not getting them mixed up, but not so clear as to the order they go, so I want to make sure that I have connected them properly in the back of the unit. If I am right on or miles away, please sombody let me know.
Thanks,
Richard
