Thank you.
An excellent write up.
so the way you have it installed if your primary battery voltage drops can you use aux to jump start from the controller you've installed in the glove box?
I did solve the problem by putting a 50amp fuse connector between the 2 posts and removing the fuse so if i need to manually connect them i just have to insert fuse. and start. i believe the head unit has failed as when i use the link it does not activate a charge.This may or may not help - I have used my aux battery to start the engine when my main battery was low and having a hard time turning over. I pressed the "manually link" button and was able to get it going with no problem. However, I recall that if the main battery was too low, then the "manually link" button didn't work properly. Hope that helps.
Ed Driscoll's post above has a picture with text that describes how to force the batteries to connect by cutting the green wire and touching it to the negative terminal - T-Max Dual Battery Install
Do you have a suggestion on how to do that?Sounds like it is working as intended. When on the charger, you'll want to have a way to manually disconnect the batteries so you can charge each individually.
So im having an issue now, i just went to Colorado for a week and my dash cam killed my battery. No problem, just hit link and start. Nope. Both are dead. So my system isn't doing the one thing i installed it to do.
I've installed it exactly how the op did. Any reasons why?
Nope. Nada. Not a thing.Do you have anything hooked up to your other battery that may have drained it?
