- Location
- United States
Hello all, I am putting my 1998 Land Cruiser up for sale. I've returned to college and I need something a little more fuel efficient. Purchased this pig in September of 2016 bone stock. She's a little rough around the edges so I will do my utmost to point all deficiencies in this truck, but a solid dependable driver. Most of the convenience items work, heated seats, power seat, rear wing windows, sunroof, drivers window onetouch up/down. My fiancée and I have made a lot of memories in this hundy and I hope whoever it passes on to does the same.
Asking $7000
Asking $7000
- 1998 Land Cruiser
- Atlantis Blue with Tan interior
- 273,648 (my daily, mileage will increase)
- I believe the last timing belt was done at 165k, the number sticks in my mind but I don't have access to the carfax anymore
- Oil changes every 5k with Rotella T6 5w-40
Aftermarket: - ARB Deluxe Bumper
- Warn VR 10k winch
- Baja Rack
- Baja Rack Hi-Lift Mounts w/ Hi-Lift (have shovel mounts as well)
- SPC adjustable upper control arms
- OME lift with medium rear springs
- Slee Diff Drop
- General Grabber AT2 285/75R16 all corners and spare
- Tough Dog adjustable panhard bar
- Trail Tailor extended front and rear endlinks (fronts not installed yet)
- Homemade two drawer platform in the rear
- Ridgid Industries flush mount reverse lights
- FCKlightbars front lightbar
- Slee Group 31 battery kit
- Group 31 Optima Yellowtop
- Weathertech mats
- Draw-tite hitch
- Wellvisors front and rear window visors
Repair Parts: - Rear gear, transfer case, front diff fluids changed 9/2016 (when I took ownership)
- Starter done 10/2016 (Cleaned the intake manifold and installed new gaskets)
- Steering flush, new rack and bushings at 5/2017
- Air Filter 2/2018
- Alternator 2/2018
- Rear Upper and Lower control arms in 05/2018
- Cat Back exhaust 6/2018
- Drivers brake caliper 9/2018
- Got into a fender (door) door bender last fall (2018). Was repaired with what I told was the last araco door in the states. Paint blending is excellent, can't tell it isn't original
- Front driver axle 6/2019
- Passenger side rear parking brake actuator replaced 5/2019
- Left bank #2 O2 Sensor along with left and right sensor gaskets 6/2019
The Bad: - Rust... The trucks been in the northeast its whole life, I will include pictures of all major rust points.
-Whole under carriage has light surface rust, nothing structural to my knowlege.
- Front Passenger fender is bubbling paint
- Rear wheel well bubbling paint
- Recently had the windshield replaced due to leakage, found a rust hole at the top of the A pillar. It was ground down , filled to prevent further leakage, and sealed well when new windshield was put in. Will attach picture of the rust hole pre-fix - Had the truck aligned when the SPC uppers were installed, alignment was good, but steering wheel is a off center. Hasn't affected drivability so I haven't bothered pulling it to center it.
- Ac is out, I don't use it often so I haven't bothered to fix.
- Headers leaking
- Could use head gaskets
- Has the factory rear locker, doesn't work though. Never got around to having a look at it
I hope the bad stuff doesn't deter any buyers, this rig runs like a top and has many more years of fun left in her. If you have any questions don't hesitate to ask in thread or PM
-Nolan
