Sweet swaybar setup
Discussion in '40- & 55-Series Tech' started by redrustbucket, Jun 22, 2005.
  1. redrustbucket
    redrustbucket
    345
    Aug 13, 2004
    Sunny Acres
    Saw this on a 40 at GSMTR. Both left and right sides have this setup. Keeps everything away from the rocks and appeaers to be adjustable. Anybody running something similar? Info appreciated.
  2. cruisergreen
    cruisergreen
    11
    Nov 27, 2004
    Utah
    Are you talking about the wrap bars?
    Looks good except a wrap bar of that design with the bar above the spring relies on the spring to be rigid in compression, which it's not.
    I'm sure it works to some extent, but I don't think it's ideal.
  3. redrustbucket
    redrustbucket
    345
    Aug 13, 2004
    Sunny Acres
    Swaybar, wrapbar, candybar? I'm a tard.
  4. Vitesse_6
    Vitesse_6
    2,257
    18
    Apr 24, 2004
    Taylorsville Utah
    Interesting idea, It looks to be well used, Must work!
    Its always amazing to see what people come up with.
    BRILLIANT!
  5. honk
    honk
    3,413
    Media:
    10
    372
    Nov 14, 2004
    PNW
    That's a variation of a bar that's been on the market for years. There's even a kit available through J.C. Whitney that does the same thing for pickup trucks - bolts with a bracket to the u-bolts and with a heim eye to attach to the spring shackle bolt. The ones I've seen have rubber/steel where this one looks to have used a spring hanger. That rod even looks a lot like the one that comes in the kit. It was around $69. a few years ago.
    Doesn't work all that well because all it really is is a glorified spring helper that stiiffens the rear half of the spring. Get one made for a truck with cabover camper, it'll be cheap.
  6. SpaceGhost
    SpaceGhost
    467
    2
    Feb 1, 2002
    Indianapolis, Indiana
    Short track racers have used a sliding bar like that for years. They run light springs, many use a single leaf set up. It will reduce wrap, not eliminate it. Wheel hop will likely be amplified.
    Chris Durham ran that setup years ago in his comp rig. So it wasn't totally bogus.......
  7. HI^C
    HI^C
    1,234
    2
    May 22, 2003
    large thread over on pirate, using cat 1 tractor arms mounted in the same manner.
  8. dustin
    dustin
    701
    1
    Oct 19, 2004
    Do you have the link? I didnt see the thread in Gen 4x4, newb 4x, and lc..??
    -Dustin
