Here is a sway bar disconnect I fabbed up. The parts are readily available tractor parts. The shafts are standard tractor PTO shafts and the coupler is from a driveshaft yoke. One shaft I used came from the gear box of a John Deere bush hog so like I said, standard stuff. All can be purchased from places like Tractor Supply. The way it works is you just squeeze the spring loaded locking pin and slide the coupler over. One position locks the sway bar for normal operation and the other allows it to twist freely. One thing will be is the cruiser will have to be in a neutral position to lock the sway bar; otherwise one side could be under pressure and the other side not. I had considered putting an air operated
spring loaded piston setup on. That way I could just hit a button from inside and it would lock/unlock without climbing under the cruiser but I don’t mind getting a little dirty. I did not do the final installation on the sway bar yet for a couple of reasons. One is I have a heavy duty sway bar on the cruiser
now which is a different diameter than the stock one and I don’t know which one I want to put it on. Also, I want to sleep on how exactly I want to make the connection. I don’t like to weld on something that is made springy to twist so I have several other ways I have thought of. Anyway, the first pic is of the basic parts.
Bill
Bill
