suspension shop around RDU
NC
I am going to have a fair bit of weight added to my 200 series soon enough (hopefully) with a 40 gallon LRA tank. A slee/dissent/etc bumper will follow eventually for the spare. I'm trying to parse through the rear spring threads and my head is spinning from the options and brands - OME/bilstein/eibach/etc o_O . Does anyone know of a reputable starting point for a suspension setup that would have good recommendations for product and a good track record for installations?
I want to maintain a fairly discreet setup (minimal to no lift - 2" or so from OEM) and minimize any ridiculous rake to keep from butchering handling on the road. TIA.
This is a fairly new Toyota shop in Raleigh. They might be worth a shot. Seems like a solid outfit. There aren't any other shops in Raleigh I would consider. There is Apex Overland in Greensboro. They seem to have a good reputation.
thanks. Without first hand experience I may be wrong, but I have pieced together from what was said elsewhere on mud the GSO outfit has butchered some work that needed to be fixed elsewhere. Again, I could be misreading the tea leaves but that's what I thought was conveyed.
I get nervous with springs under load being manipulated with the floor jacks I have at home. I don't have any experience changing any struts (due to spring compression), but cannot see a way to go about this on my rig without serious repercussions if I do something wrong.
I just completed something similar on my HDJ81. I previously installed an OME 2.5" medium lift with stock bumpers and OEM electric winch.
I ordered a 24-gallon LRA tank that fits in the spare tire well. It was installed by Main Line Overland in Charlotte who did an excellent job. I love this tank and it doesn't limit clearance. I am racking up rewards points on the CC with the price of diesel!
I also installed Air Down Gear Up drawers with slide-out kitchen.
I installed Dobinsons IMS59-60687 rear shocks, IMS45-60912 front shocks, C96-147VT, and C96-146VT springs. Best ride ever!! Thanks, @lumbee1
Before installing the tank and drawers with the OME shock spring setup, I was at 20.5" front and 22.5" rear on the vehicle's right and 21" front and 23" rear on the vehicle's left. Measured from the hub's center to the fender flare's bottom.
After installing everything I am now at 23" front and 23.5" rear on both sides with full gas tanks and the drawers filled with camping gear minus the fridge.
Main Line Overland did an alignment for me and checked my castor while I was there and the castor was off. I ordered and just received Delta VS 3" front radius arms with OEM bushings to correct my castor. I haven't installed them yet but should bring me back to OEM geometry. I looked at other solutions but decided to buy once cry once and not have to cut anything.
The truck rides fine without the Delta VS radius arms right now, but I think it will be better once installed from what I have read.
Who is GSO?
You're not confusing Apex Overland with Carolina Offroad Outfitters are you? COO has a rep.
GSO = greensboro. sorry about that.
Maybe so. I don't have direct experience with either, just trying to stay away from shoddy work if possible.
Is the rear spring setup swap able to be done solo in the garage?
highly rec suspension solutions in cary for your work. they fixed a long standing issue i had on the 62 when i had it.
also had recent work done with TEQ and they're top notch.
can't go wrong with either!
2x for TEQ Customs in Raleigh. They're located off Atlantic Blvd north of downtown. When installing my 100's Dob IMS lift, they hit some unexpected snags, made things right and got me straight. Good guys.
To follow up on the mention of Teq Customs above, I saw on F'Book (see ad below) that they are having an open house tomorrow starting at 3pm. Since beer is involved, I will probably go to check it out :D , anyone else interested?
I am looking to have lift + tires+ lighting installed on my 200 series. Is TEQ still the recommendation? I reached out to a few of the well known shops east and west of Raleigh (and one in Georgia), everyone seems pretty busy. Would love to have a local shop knock it out.
There is TEQ Customs in Raleigh, but I don’t know anyone that has used them. They focus on Toyota. But, they never answer their phone, so that might not be a good sign.
were they the ones who had a grand opening a couple years ago they advertised here?
I got a hold of them earlier this year by phone and was directled to use their email for obtaining quotes: info@teqcustoms.com. I received a quote pretty quickly. I haven't used them for any work yet so can't comment on their workmanship.
Also, I had my lift installed by this shop in Cary. They did a good job and the work included alignments at both install and then after a week of driving.
A lot of shops now seem to use email instead of phones. Those I’ve asked have all said the same thing - people call and want to talk or get free advice; they have to crawl out fromunda a vehicle to get the phone; most calls now are telemarketers. I’d stop by and see them in person before writing them off as long as you’re local.
I have gone to TEQ quite a few times and they've always been great. they remained super busy and have always had great communication with me.
Also email gives a record of what was asked for and what was quoted.
I'm old enough I like actually talking for some things but email for quotes does make sense I guess.
