I see this west aust company is making a twin screw blower for 1HZ but it aint cheap
http://www.sprintex.com.au/docs/release34.pdf
beanz2 said:Wow, leave it to the Aussies to come up with all the neat stuff
Roots-type of blowers add a lot of heat to the engine compartment. I wonder if it is an issue for them?
Dave
silvercrusher said:Do these things have an intercooler built on to them or are they strictly a blower?
Now if i put this on an engine inline with an intercooler and changed the cam to allow the exhaust valve to remain closed longer then it would be a true supercharger worth considering. Until then it is still just a blower IMHO.
Tapage said:If you have the oportunity to buy an Turbo Kit ( for diesel engine off course ) or change your engine to other with Turbo from factory ( Toyota off course ) what do you do .. ?
tlcruiserman said:I think a lot depends on the condition of the engine you have and also if the turbo'd engine will bolt up to your tranny. Example if you have a "b" engine and you want to put a "h" engine in its place, they H55F will have to be swapped out because the input shafts are not the same. In the case of 3B to 13BT tranny is fine and you get rid of glow plugs and go to direct injection so if you can pick one up in good shape at good price (probably from G&S) then might be worth it. Just my 2 cents
Cheers,
Michael
