Problem solved, put a new tank of gas and your good to go. Let us know when that fixes your issue.I was a refinery plant operator - the final product is good leaving the plant is water-free but a bad tank at a gas station is very real still in 2021.
Ethanol is a hygroscopic binder (why an occasional fill of it is good even in marine applications where ideally you want no alcohol fuel as the routine, picks up any fixed tank condensate).
— But if you live where temps fluctuate decently or any number of external factors of filling station tanks means water/soil can be present, from old unlined steel tanks that rust/leak groundwater & dirt to a simple worn seal on the filler port the tankers use to deliver from their truck to station tanks & you get a good rainstorm.
The fuel you put in your tank goes through a minimum of 3 tanks before you squeeze the nozzle - sediment is easily passed along.
Shine a flashlight in any small plastic gascan - you’ll easily see some particulate matter.
So I 100% disagree that “bad gas” is a thing of the past - to think otherwise is like thinking Taco Bell uses the exact same grade beef as Peter Luger’s steakhouse in NYC.
