sub tank overhead console wiring? (2 Viewers)
But then Kevin's write-up only has +12V
This picture from Jim's write-up says one of the wires should be -12V where above they are both listed as +12V, that would be a problem
I brought a chassis ground over from the main grounding point in the kickpanel. Kevin's diagram shows a gray gauge ground.
The fuel gauge didn't show any fuel, but I need to validate the wiring back to the tank. I ran that wire through the roof down the drivers pillar so I have full acccess to troubleshoot that once I get everything else taken care of.Comments?
Also, my fuel gauge didn't just peg up, it was slow at first.
I decided to wire it up like Kevin had it and routed wires through the roof down the Drivers A piller. The Gauge's both work but the lights don't. So here is what I did
Blue/Red = 12v+ gauge - Used +12V Ign that used for Georges ECU
Red/yellow = sending unit - Used the Fuel Tank gauge wire
Green/Blue = 12v+ light - Wired to pin1 (Green) of the Rheostat . Same as Tail Fuse
Black = reostat for the lights - Pin 3 (WG) of the Rheostat
Gray = chassis ground - Used a Chassis ground I found in the Moon roof connector. Ohmed it out
So possibly the bulbs where burnt out, I burned them out in wiring, or something else is going on. Don't think the ground I wired would cause an issue as I vali9dated it was Chassis.
To make sure the Gauge worked, I set the transfer pump while I took step #6 and watched it go down to empty.
Now I am modifying the visors, It's actually pretty easy and I will post up.
The Rhesotat back is actually easy to get to. That part of the dash will snap off on the side enough to get access to the back side where I spliced the two wires tyo the backside wires coming off the Rheostat connector
Thanks Jim, I figured out the -12V was the Rheostat pin 3. I monitored it with a voltmeter while I turned it.
That is how the OEM setup is, everything runs down to the kickpanel.
Post 'em up! That's what I need to do because we are having hell finding tan lighted short visors in Japan.
jditom,
Good job on the sunvisors, they're really look close to the original sunvisors that come with the overhead console. Very nice.
No lights, could be all the bulbs are burned out but not likely
I did not believe that all 4 bulbs would be out either. Put one in from your dash that you know works and see.
Yup, all 4 bulbs where burnt out. Probably had it working last night less the Rheostat connection. If nothing else, it forced me to wire that up.
The bulbs were green to make it look like the dash gauges. I used the bulbs from all my switches which are clear.
I could button it up now with the clear bulbs, but I will wait to get some green ones tomorrow.
Can't you pull the green covers off the expired bulbs and slip em on the new ones?
Damn, I want a subtank.
I love this site. I didn't even know you could do that.
And yes you can
Thanks for the tip :beer:
I was also going to cut/modify the visors for my install. Glas to see someone else already tried it. Do you have any closeup pics of how they sewed the ends?
Here is a close up of the sun visor mod.
Ken,
Happy to see you got her working!:beer:
Everyone, I need to verify that this gauge pod illuminates as it should.
When I connect the red/yellow wire to a positive 9 volt battery and the blue to negative, the gauge will begin to rise. (This is good, cluster works)
My question is illumination
How can I test this to verify that backlights works ?
I thought if I connected black to the negative of my 9 volt battery and the green wire to positive, I could see it illuminate. (Ignore red arrow in photo below)
Can someone chime in?
I think you have a bad bulb but for the heck of it try the grey ground wire and the green wire.
I have never dug into the overhead console bulbs. Not sure if they are like the main cluster or the ones used in the switches. The ones in the switches light up with a 9v just fine but you may need more voltage in the overhead bulbs so you might try directly to your battery.
