Maybe corrosion? Interested to hear why you are replacing? I'm having some engine stuttering at times and have replaced fuel pump/filter recently but have read these EFI relays and fuses could be a cause for my symptoms. Going to order replacements to see if it helps. ThanksIs there a trick to this? I don't want to break it off in the fuse box. I feel stupid asking this question, so fire away...
Have you changed the fuel filter yet?
Look at the Immobilizer Bypass thread. Some good info in there and he eludes to having a similar problem with his truck. From what I gather it is a basic corroding of connections resulting in some resistance and voltage loss. Enough so that the voltage is just under the amount to be able to "wake-up" the relay and thus your having it sit in ACC mode gives it enough time to energize and then start the vehicle accordingly.
My immobilizer fix
I got the famous crank but not start immobilizer problem. I replaced the 20A EFI fuse with a 30A fuse and it started right away. However, it was a temporary fix. I had the same problem again 4 days later. This is what I did to get the engine started. It has been working with no problem for...forum.ih8mud.com
I can see at least one plastic clip on the side that needs to be lifted up for the relay to release. There appears to also be a tab that needs to be depressed. No matter what I do it's not wanting to lift up, and I don't want to break it off in the fuse box.
