??? If your getting water in better make it so it cant get in anymore.
Water will damage any of them-even boats. I'm betting that the only way the military does it with these is frequent maintenance and parts replacement-they have a big budget...
As a former Army Maintenance dude, that is correct. There is a high water fording kit available for them, but that doesn't address the poorly sealed geared hubs (portals). In stock configuration fording depth is limited to 24". Also, the glow plug controller box is supposed to be waterproof but it is not. It has a metal mesh type gasket (I assume for EMP protection) that will let water in. 24VDC will do some interesting arc welding when it shorts out.
snorkle
exhaust (comes out to the side and up before rear wheel)
air cleaner extension elbow
CDR valve vent line
Hydro-boost vent line
sensor cup vent line
power steering vent line
oil pressure switch vent line
There are a few other items as well
That is STOCK in the oz manuals. The 80 has breathers/caps etc, not wonderful, but it has them to deal with 700mm. You still need to do maintenance afterwards. Once running gear is below water/mud level you would be nuts to assume that it isn't possible for some of that stuff to got into things it shouldn't have...If you are going that deep in an 80 series best have breathers installed....
Sold it ;(. Moved to a vehicle that is comfortable in that much water...
But I miss my cruiser....
So did you actually do any of the after fording maintenance before selling it?
During RAMD testing the Mercedes-Benz G-Wagon at the Aberdeen Proving Grounds, they wanted us to clean out the rear brake drum after each fording event. The mud got into everything. We eventually went to solid front rotors because of all the problems with dirt, mud, and even ice build-up. Yes, technically speaking water will eventually get into everything if sitting long enough. My u-joints are now finished after getting stuck in 3' of water last year for only 15-20 minutes.
Again, fording is the ability to cross a certain depth of water 'safely', doesn't mean you can do it without appropriate maintenance afterwards unless you want to deal with expensive R&R later...
cheers,
george.
