Strange Noise in Dash of '16 Sequoia (1 Viewer)
Tucson, AZ
Hi guys, I typically only live in the LC 60 wagon forum, but...
I have a '16 Sequoia that has the most bizarre noise associated with the air system in the dash. It only occurs in the hottest most humid time of the year in AZ. It sounds like a rather loud wild bird call. I'm not kidding. It last about 1.5 seconds and has a distinct rising/swooping pitch. It sounds as if it originates from in the driver side dash somewhere in the cabin air system. It has been a kind of funny thing we laugh about on the road, but I should probably get it taken care of before the extended warranty expires. Problem is I've talked to nobody that has ever heard this problem. I would think that it is the hinge on a damper or mixer.
Anybody have any ideas? Anybody know where I can find a breakout/schematic of the cabin air system?
Thanks
Probably a screaming mouse…
Pull the cabin filter, see if it changes.
I've owned my 08 for 5 years now and it has always "whistled" out of the vent left of the radio when you turn the fan up mid way or higher. I still haven't taken it apart to figure out why, but just attributed it to a misaligned air duct or something.
Thanks
I just bought a ‘18 TRD Sport and hearing the same thing. At first I thought it was one of my kids with their tablets. I‘m going to follow this thread to see if you figure it out.
Just back from road trip vacation in hot climate, and I learned a good bit...likely narrowing down the problem.
What I did to pre-empt/test my theory that this is a blender door on the driver side, I adjusted the driver side temp to "Lo" (max cold). I modulated the manual flow limiters on the two vents for comfort. With about 20 hours of driving, not a peep. So this tends to suggest that I took away the need for something to move to modulate temperature in the dash. Now the question is what exactly. I've got my mechanic digging up a depiction of the system in the dash so we can start to connect some dots.
Any updates on this? Every once in a while I’ll still get a noise from underneath the dash.
I chatted with a fellow in the supermarket parking lot on the weekend who has an '18 Sequoia. I asked him if he has any air conditioning issues. He said he has a...squeak from time to time. I mimicked the sound, and he said "That's it."
So this is not a one-off. I had the local dealer look for Toyota bulletins on it today. There is no specific actuator or anything in bulletins. They do say that they do have to replace actuators in them. The problem for this issue for me is duplicating it. They may have to drive around a half hour before it might do it.
Ever figure this out?
I’ve got the issue too and there is a recent thread on Toyota nation about it. No solution though.
Here is a video for those who haven’t heard it:
That's it. Nope. Never figured out specifically what it is. We hear this most, naturally when on an annual long summer trip. Thankfully, we only heard it a couple of times, and it was not as loud. We actually chuckle about it now, as our "little creature" that appears occasionally.
Thanks for the confirmation.
My 08 does this, but it's lower like a fart...blend door servo actuation. I bet if you got under there and put some fresh toyota body grease or silicone grease on it, it would likely go away.
I have a similar issue with my 2014 Sequoia. It started with a whistle then progressed to a whistle with a rattling. It only happens when I turn the vehicle off after running the AC. I've been dealing with it for over 6 years. The one thing I did notice was that my rear AC didn't blow when it was just a whistle. Now (last couple years) that the whistle is accompanied by a rattle, my rear AC blows fine. Go figure.
I've had an issue twice with my 21 Sequoia that sounds like a bird but a whoowhoowhoowhoo/vibrating at the same time. It is loud. And very random. I only have 17K miles on her but it has happened twice and is super annoying. Following this thread
Bumping this thread in case anyone has any new developments on this - my 2016 started doing this exact noise today, about 5 times on a 30 minute drive. Can’t figure out what triggers it, as the air fan/direction settings didn’t change (unless the truck moves blend doors behind the dash on its own without driver input). Would be great to figure out.
Grateful someone has a video, because I’m not sure how I’d explain it to a mechanic!
I'm not sure if this is any help, but we've driven a lot this month...probably 30 hours on the road in mostly hot weather. We heard the tiniest hint of the sound once. I am doing something different. I used to set the temp at 76 degrees in Auto. I now don't use auto, and keep the temp setting at 71. This suggests that the noise comes from a blender door that is cycling more when the higher temp is set. Try and see what you find.
