Stock height springs for an FJ60 (1 Viewer)
Hey everyone, following up here with the actual suspension refresh. There were some major delays: the springs and shocks took months to come in, then I broke my wrist in a mountain biking accident and had to go through surgery and recovery. This past holiday weekend, though, I finally got around to tackling the job. My dad was kind enough to let me use a lift at his shop on the weekend, which was a significant help.
The install was generally very straight forward—nothing really painful or tricky. The existing setup had been installed quite some time ago and not maintained, so the biggest challenge was being careful not to damage threads on the bolts that run through the fixed leaf spring mounts when trying to remove them. Also, I wish I had purchased u-bolts initially because my front ones were completely shot, but live and learn.
Having it on the lift was also a great opportunity to do a deeper inspection on any rust. The rear quarter panels have some damage from wheel spray and there is a little bubbling on the roof (not excited about fixing that), but the frame and floorboards are in great condition, which is encouraging.
I took it for a test drive this morning and the ride quality is outstanding. I need to put more miles on it for the leafs to settle in and re-check all of the bolts. Also, there seems to be a slight difference in height between the front and rear, with the front riding slightly higher, but I expect a small amount of sag to normalize that. If not, I might have to lift the rear slightly to compensate for the sag.
Next up I'll be installing a 5 speed transmission and once that's done I'll decide on final tire size to get the overdrive gearing ratio right.
One additional piece of intel on the 555 tie rod ends that I forgot to mention: the lower ends don't come with Zerk fittings, which was a little surprising, but the size (M6) is common and they are pretty cheap.
I'm not sure where you bought your tie rod end kit from but if they came from Cruiser Outfitters | CruiserTeq.com, it shouldn't be a surprise. :D
so Kurt
does this then imply that all zerk-less land cruiser tie rod ends are pre-greased for plug and play use from the OEM parts maker they come from ?
thanks for your in-site here on this tech question
matt
so Kurt
matt
I can’t speak to all manufacturers just Toyota, 555 and Joint Fuji, 555 and JF are not direct OEM’s.
you're telling me the proper grease procedure isn't to stuff it full of grease until clean grease blows out of all the cracks?
No :D
Ah, good to know! I think I got confused because two of them had Zerk fittings and two didn't. I could tell the ones that didn't had grease in them, so I didn't add any, but I'm used to greasing my own fittings, which is why I called it out. Thanks for sharing.
It never hurts to have the zerk, and on the spring-loaded drag-link ends, it's quite crucial as they do require more adjustment/maintenance by design. The other ends have the spring loaded boot retainer and can/do blow apart when shops toss the battery powered grease gun on them and fill em up :D
Hey so stocked to see this as an option. Could you post a pic of the stance so i can see what its looking like?
Cheers!
I'll definitely post photos of the stance as soon as it's off the lift out of the shop.
My dad owns a manual transmission shop (and let me borrow a lift for the suspension refresh!) and we decided to just go ahead and do the conversion to the 5-speed H55F while it was there but taking a little time because they are running through the transfer case to replace bearings and make sure nothing needs to be replaced (like the pin, etc.).
What size tires are you running? My transmission swap is almost done and I need to get new tires. I was thinking 30" or 31", which should work well from a gear ratio standpoint in overdrive with the 5 speed.
I like your plan to not go real big with the tires. Those in the photo you're questioning appear to be larger, probably 33's.
I thought the same initially, but the more I looked at them, I started to wonder if the height of the lugs was creating an optical illusion :)
7.50 R16 ,Toyota 16inch Ring Wheel. Thank you.
Thanks, very helpful. So that's just under a 32" tire, which is close to what I was thinking. I'll post a picture of my rig when it's done and let everyone know final tire size.
