Not an STLCA member, me nor the owner, but a worthy picture I think.
4xsteve said:Not an STLCA member, me nor the owner, but a worthy picture I think.![]()
Isn't this similar to what happened to you Todd?What's the problem?
Seriously what were they jumping?
My truck actually had the same thing going on but I'm lucky enough to have those studs up top so it's easier to spot as well as less catastrophic because gravity isn't working against me so much. The 80 wasn't so lucky.GSMTR 2012 my studs backed out and a couple sheared off but luckily I smelled the grease and found the problem before it resulted in this. That is the second time it has happened.
Mine sheared @ the rotor/hat junction leaving the spindle attached to the knuckle. This looks worse, but hard for me to see exactly what happened on my phone. I thought when I originally looked at it the axle housing sheared
jynx said:Dang Rance, how many rigs you got in that barn? Is that the 94 that needed the door on the passenger side or another rig?
Edit: yep, that's the one, I remember the stickers from the pics you sent me.
That's her! I pulled the driveshaft from it for a spare last November and put it back in today while Ryan was there to pick it up and........ The **** front end was making an awful sound. Looked on mud and found I needed to pull the 30amp fuse for the center diff lock. Think it might be a stripped drive flange . In low it didn't grind but when put In hi it made the noise. He drove it abt 4-5 miles home though. That's par for the course when your selling something too. Also it's idling high 2500-3k. The intake tube is broke in half do just wondering if that might be causing it to idle high. Ryan (bluehawk) has a thread started asking some ???'s on the problems.
I would tape the tube back together real good and see if that has any change on the idle.
On the front end... you'll need to tear it apart to find the culprit. Start working your way to the diff until you find the carnage.
Any big pieces of metal in the gear oil?
Sent you a PM due to Rance telling me that you are "the man".
I'm trying to contain my laughter enough to respond!
Seems like no one on the 80's forum has any answers. Most are saying to just part it out, they have no idea the potential of this truck or what I plan on doing to it. May just leave the 80's forum all together. The 60's side is much more friendly and this site is way more awesome. Thanks Guys![]()
