I'll sell it and grab another 100 if I have too.
This gets my vote.
-B-
;pThis gets my vote.
-B-
Truck transport to Slee - $750
Slee 6" lift - $3000
Battle the vibrations for 3 monhts - Priceless!
Sorry John, couldn't help it
You should buy that $13550 100 series in the for sale section
i don't see him as taking the cheap route. Hell, he has adjustable everything, new shafts, new ring and pinions with arb's stuffed in there.
Something smells fishy.
How about getting one of those shock absorbing seats they make for military water craft?
Hope it helps....
I don't see the point of discussing this issue with your truck any more. Basically every item in the drive line has been pointed out to you as a possible problem and your responce is always the same "checked out and is ok". So either you don't have a problem or you and your mechanic's tallet behind a wrench is inadaquate to get the job done.
so as I see it you have four options:
1. live with it.
2. take the truck to someone who can fix it.
3. sell the thing and get a 100.
4. raise your game and fix it yourself and then tell us what you found.
You've exhausted the web repair route at this point and it's all you now.
I agree with you. I will probably live with it. It'll serve my purpose this way.
The one thing that nags at me though is the T-case output bearings. Three folks have checked it out. They all grabbed the outputs, shook them, tried to feel for looseness. All three said they feel it's in tight and not the blame.
Is this the way to check those bearings? If not, what's the best way?
I think this is the only thing left to quadruple-check.![]()
How do you KNOW the tcase output bearing is good? If it were my truck I would replace the tcase output bearing. If that didn't work, I would take it back to 4wheelasshats to look at the gear setup.
Actually, if it was my truck, and was a dedicated trail rig, like yours is, I wouldn't care about a little vibe. Now if it was shaking off the road and pieces were falling off Harley Davidson/Oldsmobile style, that might be different.
In my 20+ years of field sevice there is always one canstant,
Sometimes you have to take s*** apart to see what's wrong.
in this case that means pulling the rear extension off of the t-case.
if your going that far pulling the t-case would be the easier thing to do. It's a few electrical connections, the 2 drive shafts, shift linkage and 8 bolts I think.
Then working on the bench with it is real easy.
