I have been having an intermittent starting problem. 9 out of 10 times I have no trouble starting at all. That 10th time is usually when I am not home and my wife needs to get somewhere.
I took it into a shop and described what was happening and they said ignition switch. I took it into the stealership and they said starter contacters. I researched a few threads and can see how it could be either one.
Here is the description of the problem. It started several months ago when on occasion it wouldn't start but if you turned the steering wheel, no problem, started right up. Eventually that trick stopped working and it just wouldn't start until the fourth or fifth try. Now, if it decides not to start, it has taken up to 10 minutes before it starts. When it doesn't start it goes like this. One click and a hum. Sometimes it will start to turn and just before it turns over it suddenly stops like I stopped turning the key.
I suspect that I am not making a clean contact either with the ignition switch or the contacters. I think, in the beginning, I was getting power to the starter but not enough power to turn the starter. When I would turn the steering wheel it would relieve some resistance on the belt that was in the power steering system and I would then have enough power to then turn the starter.
So, if it is up stream from the starter I think I am going to try this trick I found in the thread below.
https://forum.ih8mud.com/80-series-tech/211786-starter-ignition-circuit-thought.html
I think I can determine this by getting ahold of a volt meter (I will borrow one tomorrow) and seeing what kind of power is being drawn at the starter terminal.
My question. Am I heading in the right direction? If so what kind of readings should I see with the volt meter at the starter? 12 volts right? If I see less it is up stream from the starter? If I see 12 volts it's in the starter? Do I need to worry about my amps in this case?
I don't have a FSM yet. It looks like I really need to get one. Anyone know where I can get one for less than $100?
I took it into a shop and described what was happening and they said ignition switch. I took it into the stealership and they said starter contacters. I researched a few threads and can see how it could be either one.Here is the description of the problem. It started several months ago when on occasion it wouldn't start but if you turned the steering wheel, no problem, started right up. Eventually that trick stopped working and it just wouldn't start until the fourth or fifth try. Now, if it decides not to start, it has taken up to 10 minutes before it starts. When it doesn't start it goes like this. One click and a hum. Sometimes it will start to turn and just before it turns over it suddenly stops like I stopped turning the key.
Carry a pick or axe handle, every time the starter don't want to turn, tap it with the handle, works for me, at least until I get another starter,
