Hey guys, hoping you can help me out... I've gotten lots of info from different threads on here, but no answer yet for my issue.
I'll go through bit by bit in case you guys see something I missed.
Truck: BJ42 with 3b, 24volt
Issue:
Over a few days engine was slower and slower to crank and start, finally got into the driveway a couple days ago where it wouldn't start anymore. Lots of relays and glow plugs would trip when ignition turned, but no juice.
Fuel filter light has been on for about a week, even though sedimenter was emptied a couple times, without much water to be seen.
Yesterday I did the following troubleshooting:
Cleaned up all battery posts/connections
I could get it running if the throttle was pinned, but very slow cranking.
Checked battery voltages - passenger 9.7, driver 11.7 when off. (seems pretty low)
Checked fuses, all seemed good.
Checked (starter?) relay at the front driver's corner beside battery according to fsm, seemed fine.
Tried to check voltages/amperage at alternator but didn't. (let's just say I shorted the B terminal to the engine a couple times and went on to something else)
Gave up after it got dark.
Today:
Replaced fuel filter, primed and tested etc etc.
Checked voltage regulator according to fsm, all checked out, though I'm not sure how to check voltage output and adjust it, so only looked at resistances as told, all good.
Found a blown fuse in dual 5A fuse holder near battery, may have been me being clumsy yesterday and shorting things. Replaced it.
Grabbed another battery and used it to jump, engine fired up right away. Left running to see if batteries would charge. Turned off, and wouldn't turn over. Filter light has not turned off at any point in this.
Checked fusible links (only found one by battery?) connection seemed iffy, so bypassed it, jumped and let it run again, no change.
That's about it. Still jumps fine with another battery, but charging system doesn't seem to work.
Also, when it does run, if I turn on the turn signal by itself, it works, but turn on the headlights and the signal stops. Seems consistent with flat batteries?
I'm leaning towards alternator, but I've read of a few of you swapping yours but it not being the issue in the end....
Any thoughts would be great! She's my daily driver, so it sucks to have it sitting.
Issue:
Today:
