I have a 1985 FJ60. Replaced the starter about 2 years ago. So The other day I was out and about and accidentally stalled it. I started it right back up and drove about 40 ft and the engine just stalled. Rolled to a stop and it wouldn’t restart. Starter would try but wouldn’t turn the engine over like the battery was dead. A buddy of mine came to my rescue with a fresh battery and it fired right up and I drove it home. Figured the alternator went out (it looks old as dirt). Luckily about a year ago I bought an upgraded alternator and just hadn’t installed it yet. I installed it and put the battery back in (without charging it and it started right up strong as ever. I let it run for a while and revved the engine a few times and it stalled. It started right back up and then died about 30 seconds later and now it’s doing the same thing. I can hear the starter solenoid engaging but it will not turn over. The battery is showing almost 13 volts. I’m thinking it’s a bad starter but I’m kind of confused as to why it’ll start up in the first place if the starter is bad. I’m also not sure why it died both times. I’m guessing it’s a separate issue from the “no start.” I suspect I may have a small vacuum leak somewhere. Any thoughts or suggestions before I go buy another starter? Thanks for the help?
