Starter engages but engine stalls when key is released
You are getting voltage through the starter (Key in Start Position), but not through the regular ignition via the Ballast Resistor. You may have a broken wire, or a bad ballast resistor.
There is a black wire that comes off the starter solenoid and goes to the (+) side of the coil. This provides 12V when the starter is engaged.
There is another wire that comes from a metal box (Ballast Resistor). This should be "Hot" (+12 V) wne the ignition is in the ON / RUN position.
Put a meter on the coil (Black to Ground, Red to Coil (+)) and test my theory.
You can run a wire direct from +12V to the Coil (+) and if the ballast resistor/wiring is the problem - the engine will continue to run after you start it. Don't run it like this too long, or you may burn up the coil.
Regards -
Rocky
it has been about 3 decades since i drove gasser 40s. i picked up an old 1974 that would sound like it wanted to run but as soon as the key was returned to "run" it would die. this post saved me a lot of headaches. thank you for posting it up.
