You are getting voltage through the starter (Key in Start Position), but not through the regular ignition via the Ballast Resistor. You may have a broken wire, or a bad ballast resistor.
There is a black wire that comes off the starter solenoid and goes to the (+) side of the coil. This provides 12V when the starter is engaged.
There is another wire that comes from a metal box (Ballast Resistor). This should be "Hot" (+12 V) wne the ignition is in the ON / RUN position.
Put a meter on the coil (Black to Ground, Red to Coil (+)) and test my theory.
You can run a wire direct from +12V to the Coil (+) and if the ballast resistor/wiring is the problem - the engine will continue to run after you start it. Don't run it like this too long, or you may burn up the coil.
Regards -
Rocky
