So I did the whole top end rebuild thinking I had a stuck valve, it was the HG. Injectors cleaned, valves adjusted, all the bonuses. Battery died after sitting out while I slowly did the job, wouldn't hold a charge. Then alternator went, so I put another used one in it with fresh brushes.
Through all that, after the HG of course, I had it started and running several times without any starting issues beyond the dead battery. Other than the 'alternator is toast' idiot light combo, it didn't have any issues running either.
Well after replacing the alternator, no discharge problems, but now It idles too low and eventually stalls.
It's not just the ECU relearning all its altitude settings and whatnot. It starts up, runs at about regular idle for a short while, then drops to about ~500rpm, then slowly sputters itself to its death.
The key component I'm thinking here for diagnosis, is that after it stalls, if I try to restart it I can't get combustion. The starter will crank for eternity, but it won't actually turn over and run. The ONLY way to get it started is to open the throttle pretty wide with the accelerator pedal then start it.
That would lead me to assume its an air issue. It will run (albeit with a bit of fluctuation in rpm) above idle, so it's obviously got fuel and spark.
Resetting the ECU again had no effect on the problem.
In the process of writing this I've decided my guess is the IAC valve. Any other guesses that don't involve overly expensive parts?
And the throttle body has been cleaned, though I didn't disassemble it for cleaning.
