Speedy sleeve for 1987 fj60
Plano texas
Hi, Anyone know the part number for the speedy sleeve for rear differential on a1987 fj-60? Thanks,Mike
If you can measure the size you'll need, you can go to the SKF website and find the SKF / Chicago Rawhide part number. Prolly cheaper on RockAuto.
You could also replace the flange, new ones aren't very expensive. We should have them in stock
This.
I've found the speedi sleeves don't last.
CR, SKF, etc part# 99147 is the speedy sleeve for 10/27 spline F/R pinion flange or the 1pc t-case front output flange. The run ~$25 and a new flange isn't much more
FLANGE:
And do a seal and new nut 'while you are in there' AND familiarize yourself with removing/swapping flanges on diffs equipped with a crush-sleeve (which your 1987 has), it's a bit more in-depth than those with a solid spacer or stepped pinion.
SEAL:
NUT:
