- Thread starter
- #41
pics 3
pics #3
pics #3
OK:Ask away. Gives me something to do... I also entertain suggestions.
so, $2 at restaurant supply store for scrap from custom cutting boards. I would have preferred black but would have cost $$ to order from plastics store...................................1. You said you added two bolts into the cross member (in addition to the 4 factory holes in the center of the rear bumper). Where did you find it necessary to add the other two? Photos?
See post 35, top pic - to help old the weight of the assembly when open. Oh, OK. You mean 2 bolts, but in the same place....gotcha
2. Can you shoot some photos from below the bumper?
How do you mean? Underneath? Clearance? Let me know what you mean.
Yeah, just some photos from below the bumper showing how the support tube looks running the length of the bumper
3. Where did you source your high-density plastic piece?
...LOL... I looked at a lot of plastic companies with the UMHW (I think) plastic, until I realized it is also used to make kitchen cutting boards...so, $2 at restaurant supply store for scrap from custom cutting boards. I would have preferred black but would have cost $$ to order from plastics store.
Good thinking!
4. Where did you source your latch?
McFadden Dale hardware in Las Vegas. The latches can also be found online from may sellers.
OK
5. You said "will also add a locking pin for the closed position to take stress off of the latch and to allow for a security lock if I deem necessary?" What does that mean and what will it do?
The latch is pretty strong, rated for several hundred pounds, but just about every bumper manufacturer that uses this kind of latch uses one about twice the size that is rated for 1-3K lbs. I will add a bracket that can be secured by a pin or padlock (or both) that will secure the carrier closed in the event the that latch fails or accidentally flips open. The latter would be tough, as the latch us under negative pressure (takes pressure to open / close than in the locked position. But you never know what will happen on a trail or on a speed bump at high speed. This is insurance. That makes sense
6. How do you plan to position the spring pop pin and what design will you use?
If you look at the 1st pic on post 41, you will see the locking pin on the spindle. That is a gravity activated pin (pull up, fall down) which will work for now. I have to fab up a tab that will raise it when the swingout is opened, then it will drop into a hole when the stop is reached. To close the swingout, you will need to pull up on the pin. Keeps sheetmetal from getting crunched, will hold it open on a hill. My existing pin may be weak, so I will most likely upgrade it. I'll have to see that. I'm not sure what you mean on that one. Have you ever thought about using the same slider/catch that's on the rear door of a Lexus GX470? When I've been thinking about this design, I noticed the rear manual door catch on my wife's GX is pretty cool. However, I don't know if it'd be appropriate in this application.......might be worth a look
As you can tell, I really like the design you've come up with, and I want to make sure I don't overlook anything. Thanks!
This has been a brain burner to invent, build, fit, as I don't have a lot of time, and when I get into the shop it is usually for only 1-3 hour stints. Included in this time, the shop, aka Garage, needs to be cleaned up and fit for my 1 year old and 3 year old to go into. So every time I work, I get everything out, get dirty, and then clean everything up. I don't have CAD, or any engineering experience, just a lot of welding time and an active imagination. So you're pretty sure you don't want to make a few more "test mules," huh?![]()
This is great. About how much time have you put in. Can't wait to see the final piece.
Yeah, just some photos from below the bumper showing how the support tube looks running the length of the bumper..................................
