Progress Update: Swingout finished.
I've been busy, got some time the last couple of weekends to continue engineering / construction, and the swingout portion is basically done. The welds are not yet sanded flush, machanical stop pin is in, but the stop itself is not yet in.
I was not happy with how the support bar hung out away from the bumper so far at the end, so I cut , bent and welded a contour to it. Very pleased with the results.
I also did not want the swingarm to hang out too far while stowed, would look too "add on" or "Bolt On", much too like the hitch mount models that I investigated and that inspired me to do this in the first place.
Soooo, the swingarm (is this one word or two. I'll go with one) got cut and bent as well. It now sits will onboard the bumper, giving a nice tight fit, similar to a Kaymar.
The 1/2" bar that attaches the swingarm to the latch (near center) holds the weight of the swingarm / tire when latched, so there is no actual contact with the bumper at all except the 4 bolt mounting points outlined previously. This bar acts as the mechanical closing stop, so back hatch cannot be harmed, and rests on high density plastic piece. So, with this entire project, I am only using two drilled holes in the rear crossmember (in addition to the 4 stock holes.
I sat my 240 pound butt on the extended swingarm yesterday straight back and fully out, and it was very solid, more than enough for a 100+ lbs of tires and gear. The assembly latches and holds very tight wihout rattles.
In this project, I will probably upgrade the latch to a heavier on and replace my home made pin mechanism with a spring pop pin. Everything else is strong as hell. Will also add a locking pin for the closed postion to take stress off of the latch and to allow for a security lock if I deem necessary.
Left to do:
-build tire portion
-Complete mechanical opening stop / lock for open position
-Fab locking pin for closed position
-Clean up existing welds
-fab up High Jack carrier to snug behind tire at angle.
-Build / buy license plate relocation bracket.
Pics below
