- Joined
- Jun 21, 2011
- Threads
- 234
- Messages
- 21,836
- Location
- Redding, California
- Website
- trail-tailor.com
- Thread starter
- #21
Looks awesome.. glad you like the process..
J
J
Whatever bags you use just make sure they are rated/recommended for sous vide water temp.
A friend sent me a Waring sealer and bags for sous vide. I've owned and used numerous vac sealers and various bags at home but this is the first experience I have with the Waring zip/seal bags and they're GREAT! Extra mil thickness and they hold vacuum. They are also washable, which we've done repeatably without apparent degradation and a better investment long term than the non-zip closure bags (FoodSaver, etc., style) that don't wash very well and also lose minimum of an inch of bag each time they're opened. Like all strip seal/non-chamber style vac systems you need to be sure liquid doesn't get sucked up. So that's what I've been using for the sous vide.
http://www.amazon.com/Waring-PVS1000-Pistol-Professional-Vacuum/dp/B008LW73UY
As you probably know the larger commercial sous vide machines have much larger water volume than typical home crock pot capacity. And they use a circulator to insure accurate water temperature top to bottom and side to side within the water column. I think, again relative to the small vessel size of my crockpot, a temp controller sans circulator gets the job done reliably and predictably.
KLF, sorry for some reason I was thinking the pedestrian Ziploc food storage bags when I commented about heatability...and didn't realize they had a heavier duty version aimed at sous vide.
Good 411 on the bag material J!
Coincidentally we had homemade lasagne from the freezer last night. Although the servings were contained in 3.5 mil embossed vac bags (similar to Foodsaver...buy them from Dougcare Equipment) I just tossed them into boiling water for 20-minutes and dinner was served.
Although I haven't used the Waring in boiling water they've held tight at 165 no problem. I suspect J has a ton more time with them so his word better be gold![]()
How are you guys washing the bags? I've done a couple of batches of chicken breasts, came out great. Tried putting the bags in the dishwasher, stretched over the tines of the bottom rack. They're still yucky inside.
Not sure I trust hand washing.
