I have been reading around the 40 section for a couple of weeks now, and here is my first post
I drive a 1988 Fj62 at the moment, but I hope to be buying a 1980 FJ40 here pretty soon... anywho, the problem is that the 40 doesn't run... I'm not really sure why though and neither is the owner... he had to the head re-done by a shop because of a bent valve, but now (after the shop did the head) he doesn't have compression on 2 cylinders.... like 0 zilch nada!! nothing!!! not low compression zero!!!
I am thinking it is probably a gasket issue or at worst case, valve springs or valve stems, maybe even a combination of both with bad valve seats...
but i digress, I won't pretend like I know all that much about engines, because I don't! All of my mechanical know how is with a 3FE, and even that is just barely enough to get me by! I'm hell bent on getting this 40 and having her run by the end of summer so I can get some topless time
but what do you guys think about the engine? How much work do the cruiser gods foresee in my future?
I'm going to do a complete engine gasket set, and all so maybe I'll stop leaks while I am working on the engine too! I want to think I will be able to do this on my own, I have a place I can pull the engine and work on it a bit, I just wonder if I am better off just to spend the big $$$ and get someone to do it for me?
I want to learn, and be as involved as possible, but I don't want to make a costly mistake you know? Let me know what you think!
(and thanks for stickying the info in the FAQ for the buying first fourty and all that jazz, I have literally spent hours and hours and hours reading all the info I can get my hands on about these behemoths!!)
