I just did more jumping. I first pressed A/C button and fan on, A/C light stays on because switch is unplugged. Then based on the numbers in switch picture above....I jumped 1 and 2 and compressor comes on for three seconds and A/C light blinks.
Like before, I then turn A/C control button off then back with light staying on. I jump 1 and 4 and compressor comes on then off every three seconds as long as I keep jumper on it.... but A/C light does stays on not blinking.
Still can’t seem to jump fan on but I saw it on before. I hope I haven’t fried anything jumping wrong terminals.
No you haven't fried anything. I've been looking at my EWD (for a 99 LX470) and confirming the circuitry. You've gotten out a little ahead of me....but the information is useful.
Presumably your 2000 is wired the same. From what I can tell....the components I suspect now are the Condenser Fan Relay and/or the Pressure switch itself.
Line 3 comes out of the Center ECU goes to the Trinary Switch (pressure switch) and IF the switch has enough pressure and is closing the normally open contact then that circuit continues on (as line 2) to the A/C Condenser Fan Relay, from there it goes to the Magnetic Clutch Relay and finally to the Compressor Clutch and Lock Out Sensor.
Line 1 comes out of the Center ECU goes to the Trinary Switch to be completed to ground (as line 4).
So that is why I wanted you to jump across 1 and 4 (to create a known ground).
You have swapped out the Clutch Relay but not the Fan Relay and the circuit has to go through both. So that would be my next thing in the process of elimination. If that does not solve the issue....then it points squarely to the pressure switch itself or the wiring somewhere along the way.
