I am having a little trouble getting my preload correct with the pinion nut tight and wanted to make sure I wasn't overlooking something stupid.
The ring and pinion is a later style (new) that uses the crush sleeve, I am trying to use the solid spacer with shims instead. My solid spacer is approx 2.10" long with .10" in shims (all that came with the spacer) and when I try to tighten it up the preload goes through the roof. the part that is odd is the crush sleeve is approx 2.2" long and would have to "crush" to be set. So why in the heck when I start to tighten a solid spacer that is almost the same length my preload is hosed?
Just want to double check that I am not missing something before I just try to find some more shims.
thanks,
Bret
thanks,
Bret
