I'm getting ready for Baja. One of the issues I've had is draining down the aux battery which runs the Engel fridge. I've thought about getting a 15W solar panel that I can plug into the aux battery to supply about half of the needs when the fridge is running (2A x 12V = 24W), and charge the battery when the fridge is not running.
I've found a panel, but it requires a controller to prevent discharge and overcharge. There is no concern about over charging since I suspect the fridge will be running more than 50% duty if the days are warm. As far as discharge, I can unplug at night.
The only downside is the panel is 4" wider than my roof rack, but I can pack it away when we are moving since I won't need it with the engine running.
Any thoughts? The panel I'm looking at is NPower 15 Watt Amorphous Solar Panel.
