Just curious if anyone has experience with hail and their solar panel? how durable arw these things? I have a 100w Renogy panel.
He could also move some place nicer.How often does it hail in Phoenix?
Tiny hail is not as bad as the baseball sized stuff.
Minor thread hi-jack about to happen....how have you mounted your panel? Any Chance of some photos.Just curious if anyone has experience with hail and their solar panel? how durable arw these things? I have a 100w Renogy panel.
I was also looking to those who have had real hail smack their panels to see how they have held up practically.
I suppose you could fashion a hardtop cover or use cushions pillows cardboard air mattress. Last gets you dual use, small size, light weight and portability. Editor's Choice!
Likely best to just keep it in the garage. If your really contemplating taking it outdoors, be aware that weather can cause damage to the whole rig! Things like hail can do more damage than even branch scratches, exposing it to the sun can fade, make plastics brittle, etc!
Maybe something like this. Make the cover easy to remove, simply take it off when you get to the show & shine, then after, quickly replace to prevent damage? No need for anything complicated, a sheet of carbon fiber backed by foam, light and simple?
Minor thread hi-jack about to happen....how have you mounted your panel? Any Chance of some photos.![]()
I work with solar for a living and your typical aluminum framed glass solar panel is quite durable. The strength resistance to impact is similar to a windshield. They are tempered glass, usually laminated to a Mylar substrate with the cells sandwiched in between. If they do shatter they will craze like auto glass except that the slivers are smaller than auto glass and glass splinters are plentiful. Gloves are a must when handling broken panels.
The 1" hail rating is standard across the industry. In real world terms, the three things that will shatter a panel are dropping it on its corner, twisting or flexing the glass out of its flat plane, and a hard impact with a sharp pointed object (kids throwing rocks, gunfire, or dropping a ratchet on them :<) .
As part of our standard product demo I regularly smack a solar panel with a 2x4 just to get people's attention and give them a visual as to the durability of a solar panel. Haven't broken one yet (that way ) in hundreds of demos. Another interesting point is that a shattered solar panel will still produce electricity just fine. Eventually water will get under the glass and cause corrosion that will shade the cells, and then they will stop making electricity. In a dry climate I've seen shattered solar panels still continue to produce power for many years in a broken state.
Used some 10" straps I had from Home Depot, I need to trim them down yet. Spaced them a bit with a nut and they sit just under the top of the Prinsu load bars. I rigged up a "Y" connector with dummy plugs on the passenger side to splice in a folding panel should I have the tent platform deployed and really need a solar charge. I have to replace the hardware from my initial mockup yet. No roll up panel in play yet, just future proofing it.
Here's some pics:
Top
Driver's Front
Driver's Rear
Passenger Side
Solar Y-Splice
