an electrical supply house or maybe even home depo. there are voltage testers there, they look like a big pen. they ususlly have a watch battery or a AA battery.you just hold it up to the wire and the tip glows or a buzzer goes off. they dont have a prong or metal lead like the two wire type tester, they just detect the magnetic field. that might work for you. be careful and check wha the voltage range it will detect..they should be able to read DC no matter what, but most will only works on voltages between 70 volts and up or something. at the electrical supply houses i've seen ones that work at low voltages, but i've never looked at the ranges from the home depo.
