Wanted Smog pump & alternator belt tensioners
SoCal
Hi all.
Looking for the Adjusting Bar for the smog pump tensioner. Not in stock at SOR. Thinking this may be universal for other models.
Also need the tension adjuster for the alternator. Not having any luck on the SOR site either.
Got some time so I’m posting this up before I have a chance to dig into the FSM.
Thanks
Brandon
RodrigzCrzr
Culver City, CA
Hi all.
Thanks
Brandon
Order one off a 80 series Landcruiser.
Through your dealer.
I don’t have the part numbers. But I used that for mine.
Boulder, Co
Go get one from Home Depot. Grade 8 with a zinc coating should do just fine. M8 1.25 thread pitch. ~4”
1903319
SoCal
Thanks for the replies.
Sourcing the bolt is no problem. It’s the nut that grabs the pulley I need. Will look for an 80 series one.
Boulder, Co
That little bugger..... ugh.... I’m sorry my friend.
Here you go.
Search air pump adjusting bar. It should pop up. I’m not sure if it’s cheaper than the stealership but this one is $15. I think mine with the bolt too. It should work on the alternator as well.
Part # 177317-61020
SC
IMO, cruiser parts would be a last resort. They d*cked me around on some fenders for a month or so, then finally admitted they didnt have them.
Boulder, Co
That sucks a lot. I’m dealing with that on some firearms related purchases on another site. For what it’s worth, I got my parts from cruiserparts in a few days with no problems. Internet purchases are a gamble sometimes.
Spike Strip
My Truck runs on Cow Farts
Calizuela
That kind of Nut is called a 'Coupling Nut' you can find a M8 x 1.25 (for for that matter an SAE size) and weld a thick washer on it, if the 80-series won't work (I have no idea).
1903407
SC
that is why forums like this are so valuable. Pretty easy to get some answers on who is legit and who isnt...
just type in cruiserparts.net and enjoy some good stories.
SoCal
Thanks all! Just ordered two up from CP. Will source bolts locally.
65swb45
Elder Statesman
Supporting Vendor
You’ve got me thinking Alf. I think the locktab used on the transfer case idler shaft welded onto that coupler would be a ringer for that part.
Good idea!
SC
I think you could have garnished it with some 1975 Fj40 brochures, large keys, or TEQ flashlights. I am usually drooling by the last picture. Sorry, the presentation was lacking, you may not make it to round two. Not your best effort. :)
65swb45
Elder Statesman
Supporting Vendor
:p
Another case of the one way ratchet. :rolleyes:
RAGINGMATT
Factory Focus-Point Mind-Set Approch.....
Supporting Vendor
East Coast
everybody has off days .................
RAGINGMATT
Supporting Vendor
East Coast
Don't frett
there's alot planned in the pipe-line for 2019.............
1904604
