Sloshing sounds..
Hollister, CA
Website
www.bww.com
Its been raining alot here. It stopped raining one day, but I'm hearing sounds of water sloshing in my PS door. At least that's where the sounds coming from. Has anyone else had this problem with their FJ80 and what did you do to fix it?
could be the rocker panels too.
First you unplug all the drains and see if anything comes out.
Change yer font so I can read it...:rolleyes:
I can tell from my own experience that the front drain tubes of the sunroof are leaking and the water is being deposited on the rocker panel. There is a plug on both sides (DS & PS) rigth under the floorboards, remove the plug (don't be looking at it directly, I made that mistake...) and watch how the water starts coming out, very dirty water.
I am having problems with this same issue now and I am suspecting the drain tubes are either cracked or disconnected and the water is going inside the vehicle rather than outside where is supposed to be going. This is a common problem (IMHO a big Toyota design flaw/defect)
__________________________
Antonio 1994 FZJ80
The front drains empty into the rocker on purpose. The rocker drains are plugged up.
thanks I'll look into it right away.
