Slip when locked up (2 Viewers)
Arlington, Wa
I posted this in 80 series, and didn't see anything because few people run this trans.
I threw it in diesel but that forums pretty slow.
@SNLC replied and kind of confirmed my thoughts.
I figured I'd ask here to draw a larger pool. My a442f is very similar to your a440f.
Basically when you're cruising and the converter is locked, if you speed up do you see any slippage, any increase in rom beyond the speed increase?
The converter can be locked and the trans slip in OD, unlikely though with your low power engine
I'm aware that converter lock up can be over come.
I'm trying to see what is normal on these transmissions.
If everything is functioning properly no there won’t be any slip… that’s what locked means
Is that a more clear answer?
My transmission prior to failure was exhibiting 200-300 rpm of slip. I have a feeling my pump was failing and I want to verify when I get the trans back these symptoms aren't normal and no longer exist.
I have zero experience with a land cruiser and was unaware how tight lock up was. So I was trying to get a comparison from similar vehicles.
Is that clear enough?
Howdy @Dusten
When my tc locks up, I don’t get any slippage. And, as you noted, when passing (with my pedal to the darn floor) my tc goes out of lock up, then locks up again after I lay off the gas. No slippage.
Have you had any news from your shop?
Make sure that they adjust your kick-down cable to within factory specified range. If the cable is adjusted out of spec it can muck with proper shifting.
Got the hdj81 back from the shop today. The transmission exhibits zero slippage when the converter is locked now. I believe the trans was failing for an extended period of time and I assumed it was normal.
Right on man. That is excellent news. Here’s to hoping that your tranny runs like a top and stays that way. 🍻
What was the fix for you?
The fix? A complete rebuild again
After rebuild #1 the bushing in the front pump spun and the pump wasn't building enough pressure
While this occured the converter was damaged, and wouldn't fully lock up anymore. It would slightly slip when engaged. During a long hill I overheated the trans due to slippage and cooked everything.
All this was covered under warranty.
I've had absolutely zero issues since.
