Endless Horizon Outfitters is pleased to announce that we are the new US Distributor for the amazing Slinky Long Travel Suspension systems! As many of you know these suspension systems have been proven for years in all conditions in Australia and are now available here in the US as the "Ultimate Tourer" suspension. You won't find a better ride, better performance or more flex from any other bolt-on suspension system out there. Whether you want to play in the rocks, go fast in the desert, or load up for a 2 month overlanding adventure, the Slinky kits will handle it all!
Overlanding & Off Road Gear | Toyota 4x4 | Endless Horizon Outfitters
We will be updating our website soon with all the new products with availability and pricing.
EHO will have a full lineup of kits available soon for the following applications:
'91-97 80 Series Land Cruiser/Lexus LX450
'98-'06 100 Series Land Cruiser/Lexus LX470
'07-Present 200 Series Land Cruiser/Lexus LX570
'06-Present FJ Cruiser
'02-'09 Lexus GX470
'10-Present Lexus GX460
We are also working on bringing in kits for the Tacoma and 4Runner.
First shipment of kits are on their way from Australia and we expect them to be available in 4-6 weeks.
Plans are to have a new shipment delivered each month with a new product line introduced every 1-2 months. We will update this thread with announcements of new shipments arriving and which kits are part of the shipment.
As of now the 80 series kits are the most popular but we expect other applications to match the pace. Here is a basic breakdown of what is in the 80 series kits. Kits will be available in 50mm or 75mm (2" or 3" lift) with intermediate or heavy spring rates.
Stage1 80 Series Kit
Stage4 80 Series Kit
Recommended Optional Components also available
Adjustable Panhard Rods front and rear for both 2" and 3" lifts
Caster correction plates
Slinky HD Lower Control Arms rear
Slinky HD Adjustable Upper Control Arms rear
Slinky Radius Arm offset chassis plates (for 37" tires)
For IFS applications Blackhawk upper control arms are available
'02-'09 Lexus GX470
- Front 2.0" Aus spec Toyota 80 Series TD and Petrol model Slinky Long Travel shocks
- Rear 2.0" Aus spec Toyota 80 Series TD and Petrol model Slinky Long Travel shocks with shock boots to protect shafts.
- Tapered wire Dual Rate Coil springs with custom spec coil rate
- Swaybar spacer kit (required for clearance of front driveshaft at full droop)
- Install kit (Bump stop drop adapters rear, rear swaybar brackets)
- Brake Lines
- Front 2.5" Remote Reservoir Aus spec Slinky Long Travel Shocks with CDC adjustment
- Rear 2.5" Piggyback Reservoir Aus spec Slinky Long Travel Shocks with shock boots and CDC adjustment
- Install Kit (bumpstop drop adapters rear, rear swaybar brackets
- Brake Lines
