I just ordered a ARB winch bumper and AC dryer skid plate from Slee. I dont have the cash for a whinch yet so I'm leaving it open for now. I see that you have the slee fairlead on you ARB. I asked Christo about mounting one of those on untill I get the winch and he said that it dose not fit that well on the ARB. do you have any close up pics of it on your ARB? did you have to mod it to fit?
I was thinking that maybe they just do not want to see the company name on a competing product and I can totally understand and respect that
. there is a 95% chance that I will be going with a Roller fair lead that comes with the Warn. Really just curious.
The reason I went with the ARB is that this is my DD and also I really like seeing the top tube up over the hood while driving. reminds me that its there.
I went with the Hawse fairlead because I was going to run synthetic rope and the "word" was to run a Hawse with synthetic. Opinions differ on this and many feel that a roller fairlead, with new rollers (or very lightly used ones) is acceptable if not preferable. You just don't want anything snagging the rope.
I went with the Slee fairlead (over other Hawse fairleads) because when I saw it at Christo's shop it was bling bling baby
. What I didn't realize at the time was that it wouldn't line up "perfectly" on the ARB. If you look at the pictures below you'll see what I mean in that the fairlead sits low in the winch line opening. What I discovered is that if you want things to line up you need to buy an offset Hawse fairlead (see this Rising Sun thread for more info -->
Click Here). As you will see I was being very anal about the whole deal lining up
Anyway, one solution would be to drill into the ARB and the spacers required to mount the XD9000 winch, tap the holes, and mount the fairlead up a tad - problem with that is I probably wouldn't be able to clear the lower winch mounting bolts and I can't move the winch up (using the upper most winch mounting holes) as explained on the thread on Rising Sun. In the end I just left everything where it was (as shown in pics) after wasting WAAAY too much time over analyzing the crap out of it. Until now I haven't thought anymore about it.
I can almost assure you that Christo doesn't mind his products being used on competitors stuff (if you can call it that). He is just being honest with you so you know up front what to expect. I discussed the "issue" with Christo a few times so I would imagine he is just passing along what has been learned
As for the roller fairlead, I can always swap down the road but I probably never will (too much of a PITA to do so). The ARB comes with the longer vertical bolts to mount the roller fairlead but everything would have to come off to get it done (winch and ARB). To mount the roller fairlead you have to sit the fairlead "frame" (without the rollers installed) on the ARB, then using the ARB's lower bolt holes as a template, mark and drill the
fairlead frame for new mounting holes. What you don't want to do is to drill the ARB to match the fairlead holes. The lower winch bolts, which are used to attach both the fairlead AND the winch to the ARB, use the factory ARB holes. Drilling new holes into the ARB to match the fairlead will amount to wasted time and two useless holes in your brand new ARB
As for what TiredIron did...Well I'm not sure. Looks like he chose to have the winch line come out from on top of the winch versus from the bottom for some reason
. I'm no where near that level in the mod department.
So, here are some close up pics of what the Slee hawse fairlead looks like mounted on an ARB. In the pics you can see the little odd triangle shaped areas at the top left and right of the fairlead. The winch line opening is a rectangle shape, the Slee hawse fairlead is not. In the end I think it came out looking just fine but your (and others) opinion may vary
