Dang that is a clean engine bay! That air cleaner assembly looks right at home. Is that an oil-bath type?
It’s an air filter housing from a 74 with a 1f. Mechanic had it handy and we just painted it up to look pretty. The 2f air cleaner that should be on there is a wider triangle shape sits on top of the engine block and justifies the hump in the hood of the 55s staring in 1975 (I believe).
Ok Mark, ready for the post mortem. Here’s my report.
More to come.
- Missing accelerator pump linkage-what brought you in.
- Went to move the choke breaker out of the way to get better access to the mounting nut by the booster and discovered your installer plumbed the diaphragm to a vacuum advance port on the carb base. This has no vacuum at idle, so it makes the CB useless.
- None of the mounting nuts had lockwashers, and two of them were barely tight. Granted, There is not always enough threads on the mounting studs for a full split washer. When that is the case, I use a serrated flange nut to accomplish the task. And that is what you will be getting on reinstall.
- As mentioned when you dropped the truck off, the secondary diaphragm is the FJ40 type, which is too long to actuate the secondary on a FJ60 type carb.
- The two bolts that hold the fuel bowl to the throttle body also did not have lockwashers. That’s a 101 fail on the rebuilder, just like the diaphragm.
Oh, and there were no washers between the main jets and the carb.![]()
