Sorry to offend anyone. My statements are not meant as concrete end-all proof. Simply stating my opinion on certain modifictions.
Let me re-state...
Vents in the hood may reduce temperatures SLIGHTLY. Will it make a performance difference on 80 series? More than likely not. Will it lead to cooler intake temperatures? Probably not. Then what is the benefit? Not much IM MY OPINION, to justify the work.
Will an A2A intercooler mounted on top of the motor, and under the hood in one of the hottest possible parts of the engine compartment lead to cooler intake temperatures? Sure, it will, a little. Will doing an A2W in the same spot or an A2A in a better location lead to exponentially greater gains from lower intake temperatures? Yes, definitely.
And with the spark plugs from your other thread. I've dealt with all sorts of various plugs on turbo charged applications, and I can tell you that although copper plugs are popular, properly chosen iridium plugs will perform simlarly and last many many times longer. Personally, I don't see the reason to switch spark plugs at every oil change simply due to the fact that copper is a better conductor, unless you have some serious proof. On another note regarding spark plugs, have you ever seen a copper plug with a melted head after installing upgraded ignition components? Yup, it happens more often than you think. Have you ever noticed that sometimes when you remove your copper plugs they are at a LARGER gap than when you installed them? Yup, it happens. Again, all opinions, based on experience, I'm not simply on here blowing smoke.
