Ohhh... they also have them in cool white AND amber illumination. White housing, but I have a can of spray paint. Hmmm...
New lighting elements include
1) Rock
2) Scene
3) Forward Spot
4) Rear Fogs
I second this. I put a pair of Baja rock lights on my rear hatch so I could have bright white lite for certain things bit the bugs go crazy for them. I’m getting a second set of red to have for this reason.
would be nice if the Baja with push-buttons could be dual-mode...
How did you mount the lights near the fog lights?
You inspired me to do the same. I didn't want to run another wire from my Switch Pro to the rear so installed two dimmer switches which also turn lights off. Blue Sea fuse block (hidden in jack compartment) in rear is controlled via Switch Pro. Waiting for another grommet to arrive so I can run power through the rear door to roof. Have spare aluminum sheet and will use to cut out brackets.Scene lights on stock rack. Tried to keep this as low profile and stock looking as possible.
Made a stainless steel bracket (no chance for rust) that hangs onto the inside slot of the stock rail. Used some hardware left from an extra cross bar I had from my 100-series. I can slide it back and forth as necessary to adjust against the crossbars.
Controlled by SwitchPros which has a dimming function and Bluetooth control via phone. Looking forward to the next campout.
What kind of light strip did you use for the scene lights? Nicely done!
