Slee changed from an add-on extension piece for an oem terminal to billet pieces. They now make both a "long tail" version with post hole on end for aftermarket batteries with center terminal posts and a "short tail" unit with post hole centered to fit oem battery without too much overhang. This solved the only “issue” that I know of. Now some don’t like the price, but they are great designs with excellent material and craftsmanship.
*** Edit *** reviewing my photos remind me that I actually used a hybrid of terminal posts. I stayed with the Slee long on POS terminal but only switched to the short on the NEG terminal where space was an issue. Shorts would work in both positions, however i was too lazy to start over with something that worked.
1st and 2nd pictures are the "short tail" (my name, i forget what slee calls them). They do not come in black, I coated the POS terminal with electrical insulation rubber.
Third pic is the long tail negative terminal, you can see how it doesn't really fit a battery with posts near edge. Yes I purchased 4 different typical of posts SDHQ, ebay, and Slee original long and before settling on the slee short tails.
Fouth picture is as of now, my system is still a work in process. Some wiring harnesses in place, others not, some parts in place or in garage others backlogged. About only things running right now are internal center console usb ports and rear cargo area power outlets. Wires run for roof rack lighting but no rack, wires run for front grill OnX6 arc light, but no light. Air compressor ready to drop in, but until final aires run on drivers side, I can't block access to the firewall.
Last two are SwitchPro setup and terminal strip inside of RH Terminal Box lid, awaiting for my custom battery mount to hold its power supply (LFP aux battery).
