- Thread starter
- #101
The OEM water/fuel separator is now installed. I had originally used an old Racor that was laying around the shop and it appeared to work well but every once and a while the truck stalled due to an air pocket in the fuel system. I could see no leakage and a pump or two on the primer usually got things going again. After much brainstorming I thought that the Racor, which was mounted up under the hood, was higher than the remainder of the fuel system and thus potentially under "vacuum". I pulled the Racor out last winter and it has not stalled due to air since then. On a diesel however, water in the fuel is NOT your friend so a separator is important. I decided an OEM Toyota which bolts to the frame rail would be the best choice as it is down low and thus always "pressurized".
As you can see in the dash picture, the red light (red arrow) is for the separator, it comes on on startup, so you know it works (just like all dash idiot lights) and then once running it goes off unless there is a problem. You can also see the push button for the glow plugs (yellow arrow) for preheating the glow plugs before starting. The pyrometer (green arrow) tells me the engine exhaust temps so I don't melt my pistons. It's color coded too, green for safe, yellow for getting close and red for the danger zone! The purple arrow is the boost gage for the turbo.
Next up, once there is a time when the tank is close to empty on a weekend, is the long range tank!!
