Selling my 97' 40th Annv. 80 Series
Kansas City, Missouri
For personal reasons I'm must sell my 1997 40th Anniversary 80 series Landcruiser. As most of you know this is a near perfect rig that has been babied all of its live. I have had many people tell me it is the cleanest 80 series they have ever come across. What is most impressive beyond its condition are the maintanence records that have been kept with this vehicle from the day it was driven off the lot. I have a book of over what seems like 1000 receipts of everything that has ever been done to this truck. I went through all of the oil change receipts last night and there has NEVER been more than 10K miles between oil changes in its entire life. Mostly done between 7K as an example of the care that has been made to maintain this truck.
Details:
1997 Toyota Land Cruiser 40th Anniversary Edition
Miles: 228K
Selling Price: $30,000
Traction / Suspension:
Factory Front/Rear Electric Lockers
7 Pin center diff lock Mod
Old Man Emu Springs - OME851 / OME 860
Old Man Emu Shocks - N73 / N74E
Old Man Emu Steering Damper - SD24
Old Man Emu Caster Correction Bushings - CA77B
1” Mr. Gasket Front Coil Spacers
Armor:
ARB Winch Mount Bull Bar
4x4 Labs Rear Bumper
Custom Sliders
Custom Transfer Case Skid Plate
Tires:
NEW - BFG A/T KO2 285/75/16 put on @ 217K miles
Snorkel:
Safari Snorkel - SS81HF
Brakes:
Front DBA Drilled / Slotted Rotors - 4784XS
Rear DBA Drilled / Slotted Rotors - 4786XS
100 Series Brake Pads Front
80 Series Brake Pads Rear
Slee Stainless Brake Line Kit - STF1021
Lights:
IFP 930 Super Rally Lights - s9314
LED interior dome and door lights
LED reverse lights
LED license plate lights
Radio / CB:
Uniden CB Radio
Clarion VX400 Sterio - 0625AB
Clarion SRG-1621 front speakers
Memphis PR462 rear speakers
Power Base Sub
It’s History:
Original Owner
The truck was purchased new on April 12th, 1997 from Seeger Toyota in Creve Coeur Missouri (suburb of St. Louis, MO.) The original owners were meticulous, non smokers, maintained the truck in every aspect per the recommended maintenance schedule offered by Toyota. Original owner maintained the truck at Seeger Toyota as well as Lou Fusz Toyota in St. Louis over the time of ownership.
2nd Owner (Me)
I purchased this truck from the original owner (it was for sale by owner) on Oct. 20th, 2004 with 143K miles on the odometer. I owned the truck built it up and enjoyed from Oct. 2004 to Nov. 2007.
3rd Owner
Sold the truck to Andy Harris (owner of Voodoo LandCruisers) in Nov of 2007 with 165K miles on the odometer. Andy continued the over the top maintenance that the original owner and I had kept over the years + more.
Purchased it back
As time had passed I missed the truck so much that I convince Andy to sell it back to me. I purchased it back in Nov of 2013 with 190K miles on the odometer.
The truck has only had 3 owners in its life. It has been loved, babied and has always been maintained with factory Toyota parts from the day it was new. It was more than likely overkill but worth it IMO to use Toyota parts for everything.
Recent preventative maintenance completed (all receipts available):
Tires (217K):
  • BFG A/T KO2 285/75/16 put on @ 217K miles
Belts (210K):
  • Belts - 90916-02353-83 & 99332-10910-83
Ignition (210K):
  • Denso spark plugs - 90919-01176
  • Denso Cap
  • Cap o-ring
  • Rotor
  • Wires
  • Distributor o-ring
  • Replace Alternator Brushes
Fuel (210K):
  • New fuel injectors & gaskets x 6
    • Replaced ALL fuel injector electrical clips x 6
  • Fuel filter
  • PCV valve & hoses replaced
  • EGR valve replaced
  • Throttle body cleaned
  • Replaced upper 02 sensor w/ Denzo (to resolve P0171 error code @ 219K)
  • Replaced knock sensor #2 (due to “knocking it” while removing head)
Cooling System (210K):
  • Fan Clutch
  • Replaced water pump
  • Thermostate
  • Upper / Lower Hoses
  • Hose #2
  • Hose #3
  • Replaced pesky heater hose w/ silicone hose
  • Replaced ALL rear firewall heater hoses
  • Idler pulley replacement
Head Rebuild (external head gasket leak identified / NO overheating had ever occurred @ 210K)
  • Milled / Machine Head Job
  • Complete valve grind kit
  • All new OEM head studs
  • Replaced EVERY vacuum line with OEM vacuum lines
  • New gaskets, studs, bolts, ect…
  • Replaced just about everything that could be replaced or might be considered a worn item with head removed.
Drive Shafts:
  • I have all new Toyota Spider bearings and clips ready to go into drive shafts.
Brakes (219K):
  • New 100 series brake pads & 80 series rear pads
Power Steering (210K)
  • Replaced power steering pump o-ring
Front end birf rebuild: Was completed at 143K and done again at 202K
  • Complete kit both sides
    • Upper/Lower truin bearings
    • Upper/Lower Seals
    • Inner axel seals
    • Inner / Outer wheel bearings
beautiful rig!! I believe your second post has the mileage wrong. must have made a typo.
YEP... Thanks! Updated to reflect my 100K mile mistake ;)
A pic of the vehicle service records from the day it was new to this week. I have original copies as well as photo copies bound in a book in chronological order of year, month & date.. crazy right?? ha...
A screenshot of the fluid change history on the truck. I'm sure i missed a few things in this list but the receipts will provide greater level of detail if one wants to dig into them.
Is this some evil plot to purchase this car a third time in a few years? :rolleyes:
Sorry to hear you are parting with it. Good luck with sale.
Hey Zane. We camped next to each other at SMORR last Fall. I've got the same rig but well beaten now even at only 178.000. Same SLEE kit, different sliders, #4567. Don't sell ! But if you do I hope you get top $ for this super clean rig. I looked it over at SMORR and it is nice!
Its only for sale on months that don't have R's or E's and only leap years.
